Hi,
first of all I realize that I run a risk of flogging a dead horse with this thread, I know that I in the past have read posts similar to what I am about to write. However I've just finished searching the forum up and down without finding more than a single line here and there about the subject.
So here we go:
1st time poster from overseas with a pipedream.
I am planning a race bike build to compete in the Nordic "Supermono Cup". We are talking about a road racing class equivalent to the AHRMA "Sound of Singles" in the US, only difference being that displacement is capped. Basically everything is allowed as long as the engine is a 4 stroke naturally aspirated no more than 800cc single that runs on pump gas.
I am planning a trellis chassis with high end suspension and mag/CF wheels.
Competitive bikes in this class usually fall into 2 categories:
- 450cc MX engines with 125GP like chassis. Looking at down to 220lbs wet weights
- larger engines in 250GP like chassis. KTM LC4, BMW/ROTAX 650 and similar engines. Wet weights in the 290lbs area
The ROTAX 650 is by far the most popular engine in the class.
Soooo...how bout basing the build on a Testastretta?
Yes, I am thinking about replicating the dummy piston design of the Supermono
Possible Pro's:
- Through the roof cool factor
- RWHP. The reliability of the Rotax/LC4 and similar engines apparently starts to free fall on 70+ RWHP builds.
Possible Con's:
- Engine weight
- Chassis length limits if H cylinder kept
Related to this I have some questions that I was hoping you guys would want to answer:
1) Anyone know the weight of the complete Testastretta engine?
2) Anyone know the weight of the Testastretta head & cylinder?
3) RWHP. I keep seeing 180RWHP Testasretta dyno curves. This leads me to beileve that approaching 90RWHP could be possible with a Supermono replica engine. Or is reality perhaps a little more complicated? Even 80 would be awesome. What's your thoughts?
4) Kaemna in Germany is planning a similar build based on their Demon platform:
Ducati Aprilia Kmna - Tuning-Parts Catalog
Kaemna clearly states that they will keep the horizontal cylinder. That's what Ducati did too when they made the Supermono.
My plan was to keep the vertical cylinder and shorten the trellis frame in front of the engine. Compared to the xx98 I would be aiming towards a shorter (by around 4") wheelbase and a longer swingarm. Geometry would then be 250GP ball park. Getting rid of the H cylinder seems to be the way to go to achieve this. It would also center the engine mass around the CoG of the bike. But what do I know? Kaemna and not to mention Ducati seem to know what they are doing!
Which cylinder would you keep?
Any other thoughts on this build?
Best Regards,
JT
So here we go:
Possible Pro's:
Possible Con's:
- Engine weight
Best Regards,
JT
