STOP! unless you absolutely want the immobilizer, don't go spending thousands of dollars on ignition etc... you can reflash the dash, bypass immobilizer and be ok with just a few hundred dollar dash... doesn't have to be virgin.
I am going through same project/problem right now.
Also, here is a great way to do it yourself and keep immobilizer as well actually:
message from Gilly on this forum: "using DucatiDiag. Free software. You just have to purchase two common cables via amazon. Flash license is $140 ($100 Euros), which lets you disable the immobilizer, upload maps, change rev limiter etc.
It's all in my "Oh My" thread on the SF board.
http://www.ducati.ms/forums/138-stre...0-oh-my-5.html
If you want to flash additional ECU's, it's just 50 Euros each.
The software was written by "JP" of France. And it works. There are also options to re-virginize the ECU I believe, which in the case of a different dash, would allow you to keep the immobilizer. I'm not 100% on that part... but all the rest is gold!
__________________"
I still need to do it, but before spending all that money, look into this solution
